Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through September 20, 2005
Old    Jeff Newton (jnewton7)      Join Date: Jun 2005       08-25-2005, 9:43 AM Reply
I was wondering if anyone has had any experience with this. Get an aereator pump, hose, and the adapters should be the same thing, right?
Old    Stephen Higgins (srh00z)      Join Date: Jun 2003       08-25-2005, 9:47 AM Reply
That is all I did and I bought the pumps at Wal-Mart, they worked as good as the one that I got from Fly High and it was the same model number pump.
Old    Scott Taylor (taylormade)      Join Date: Jun 2001       08-25-2005, 11:38 AM Reply
heh heh... yeah, I thought EVERYONE did this?? Only problem I had was finding the waterbed attachments. Had to find a waterbed store and they're few and far between these days.
Old    Tony (guitsboy)      Join Date: Aug 2005       08-25-2005, 2:37 PM Reply
Im using dual attwood 750's from walmart to fill. Fills my 600# locker sac up in about 4 minutes.
Old    Scott Taylor (taylormade)      Join Date: Jun 2001       08-26-2005, 5:24 AM Reply
I actually have a 750 to drain and then a 1200gph bilge pump to fill. but then again, I'm filling up a fat seat, two full sacks, and three tube sacks.
Old    Doug Wolgamot (dsw27)      Join Date: Jul 2005       08-26-2005, 6:49 AM Reply
I have an '89 MC Prostar 190. I bought an attwood 750 aerator pump that you can get at fleet farm or any other hardware store for about $20. I found a 55 gallon plastic drum. I wired teh pump to the battery and through a switch. I bought about 6 feet of plastic hose and pump the tank full. It takes about 5 minutes to fill and adds around 400-450 lbs. It sits between the motor cover and the backseat so you can still sit in the back if you want. Total cost was probably around $50.
Old    David Williams (wakeworld)      Join Date: Jan 1997       08-26-2005, 8:51 AM Reply
Here is an article on it: http://www.wakeworld.com/getarticle.asp?articleid=94
