Old     (steve142)      Join Date: Aug 2005       08-16-2005, 7:33 PM Reply
i've landed this trick like 5 or 6 times, i first landed it like three days ago, and when i went out today i did one perfect on my first try. my problem is that i might land like one and then i miss the handle every time. any advice?
Old     (steve142)      Join Date: Aug 2005       08-17-2005, 10:37 AM Reply
anyone?
Old     (cwbrider16)      Join Date: May 2004       08-17-2005, 11:12 AM Reply
concentrate completely on the handle pass, since it is the main part of the trick. also once the handle is in the other hand (after the pass) it can be used to pull you around.
Old     (steve142)      Join Date: Aug 2005       08-17-2005, 8:54 PM Reply
ok thanks for the help i will do that next time i go
Old     (brian0384)      Join Date: Mar 2004       09-12-2005, 7:25 PM Reply
can someone explain how to do an off axis 3, i'm very curious to learn but not sure how to throw it off the wake???
Old     (atlsackedup)      Join Date: Mar 2005       09-13-2005, 7:25 AM Reply
How do you decrease the tension on the line to make the pass...or is the tension going to just be really tight due to the nature of the trick. I've tried this one about 3-4 times and can't get the handle. Handle gets too far away from me and I keep reaching until I crash.
