Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through August 20, 2005
Old    patrick_o            08-14-2005, 4:31 PM Reply
Hey, im lookin to get a new baord. i ride a 134 motive right now, and i want sumthin that is a little more on the advanced side. I'm around 5'8 145 ne suggestions?
Old    vcamper            08-14-2005, 5:51 PM Reply
I rode the motive 134 before i got my new LF Substance and absolutely love the board. It has the same feel as the motive just A LOT more pop.
Old    patrick_o            08-14-2005, 6:43 PM Reply
Im kinda on a low budget
Old    Clinton (just_board)      Join Date: Jul 2005       08-14-2005, 6:47 PM Reply
how low is low?
Old    patrick_o            08-15-2005, 5:39 PM Reply
Somewhere around 250 300 andthats with a trade in
Old    English (kristian)      Join Date: Nov 2002       08-16-2005, 4:09 PM Reply
Hyperlite state 135
Old    Nathan (bladerunner)      Join Date: Jul 2004       08-16-2005, 4:26 PM Reply
go for the substance. its a great board. If you're looking for something cheaper check out the obrien oasis. great board with great pop and its cheap. only 200
Old    Paul Bernier (wakeriderixi)      Join Date: Jan 2004       08-16-2005, 4:53 PM Reply
3DS or TFD
Old    patrick_o            08-16-2005, 6:17 PM Reply
Yea i was lookin at the 3ds or tfd. Anyone have any input on the Balance or the subject?
Old    Cody (loudontn)      Join Date: Feb 2005       08-16-2005, 6:21 PM Reply
If you can unload your board and get some $$$ for it, hit up eBay for a Substance. You can get an '05 138 for between 250 and 300. You can probably get smaller/larger sizes cheaper.
Old    Paul Bernier (wakeriderixi)      Join Date: Jan 2004       08-16-2005, 11:09 PM Reply
subjekt is an awesome board just rides too deep in the water for me..... gotta ride it at least once though
Old    patrick_o            08-17-2005, 2:57 PM Reply
Should my motive be cutting in the wake fast or on the slow side?
Old    Paul Bernier (wakeriderixi)      Join Date: Jan 2004       08-17-2005, 3:00 PM Reply
motive is rather fast...... not as fast as the TFD but it is continuous rocker.
Old    patrick_o            08-17-2005, 4:20 PM Reply
I think I WANT SOMETHIN WITH MORE Upward pop and edge hold
Old    Paul Bernier (wakeriderixi)      Join Date: Jan 2004       08-17-2005, 5:22 PM Reply
still in line with a TFD or 3DS..... its a faster board then the motive. Has four fins instead of two center fins. Its abrupt continuous rocker meaning it keeps its speed and fluid consistent pop but explodes of the wake better then a normal continuous rocker. It has the SOFTEST landings of ANY board out there. If you buy it you need to replace the stock fins with smaller .8 fins to use the board at its potential.
Old    patrick_o            08-17-2005, 6:25 PM Reply
Does anybody know where I could get e tfd for relatively cheap?
Old    Paul Bernier (wakeriderixi)      Join Date: Jan 2004       08-17-2005, 7:56 PM Reply
ebay for a cheap TFD... but I was thinking..... you like the Motive but want something thats a step up.... have you considered sticking with the same theme and giving a Belmont, Temet, or Murray a try? That is the order that Shawn Murray came out with his newer boards. TFD will take you more up on your pop, will be faster, will be looser, and will land softer. Belmont will track tighter, ride faily fast, basically feel like a bit more performance then your Motive. Make sure its a 2002 or newer Belmont though because anything less and its your Motive shape just with the Belmont name.
Old    Paul Bernier (wakeriderixi)      Join Date: Jan 2004       08-17-2005, 7:57 PM Reply
Out of the two boards above though...... The TFD is more advanced.
