Old    eric fox (fox)      Join Date: Jul 2002       08-10-2005, 9:04 AM Reply
Not that I am advocatining stealing music, because I am not, but I purchased some music through Itunes and would like to use it in a video I plan to make. Windows movie maker does not recognize the format of the file and I would assume a lot of other windows based programs would have the same difficulty. Is there anything you could suggest to either create the file in MP3 so it can be used...or an editing program for PC that allows the use of .AAC files?
Thanks,
Eric
Old                08-11-2005, 2:28 PM Reply
look for a .acc to mp3 converter on google. if that doesnt work, you can set your record properties to "what u hear" or "stereo mix" or something... then hit play, then hit record with your recorder.
Old                08-15-2005, 6:39 PM Reply
Or, you can write it to CD from ITUNES and import it from there. It's an end around, but it will work.
Old                08-18-2005, 1:04 PM Reply
Try
http://hymn-project.org
