Old                08-09-2005, 12:57 PM Reply
hey when you do a heelside 3 i always turn my board into the wake to help the spin but the handle if to far away then. do u pop then start spinning or start spinngin right off the wake?}
Old    Paul Hancock (aquaticaussie)      Join Date: Aug 2004       08-09-2005, 1:44 PM Reply
Mike,
Pop and then start spinning.
If you start spinning right off the wake you will end up with trouble bringing the rope to the small of your back. If you wait you can then pull to your back hip which helps the rotation and gets the handle in the right position for the pass.
Of course easier said then done.
Old                08-09-2005, 2:30 PM Reply
edge in with a smooth relaxed edge in a seated position. think of it like a normal wake jump. for hs spins think of the pop off the wake like doing an ollie on a skateboard. you want the nose of your board to be up. at the peak of your height, pull the rope in with both hands to your back hip and look in the direction you're spinning. keep the handle close to your body and pass it.
