Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through August 20, 2005
Old    Kipp (sturdyboardz)      Join Date: Feb 2001       07-30-2005, 8:30 PM Reply
wondering what everyone does to keep their boat carpet clean, or what the easiest way to wash it is.
Old    Psyclone (cyclonecj)      Join Date: Jul 2001       07-31-2005, 10:25 AM Reply
The easy way is to scrub it by hand and just wash the dirt down into the bilge with a hose. Takes a long time to dry, though. I use my carpet machine, pull the seats and clamshell and run it right in the boat. Use the hand tool for the corners. It cleans up pretty well.
Old    Delta Force (wakebordr11)      Join Date: May 2001       07-31-2005, 6:59 PM Reply
hose it down, scrub, rinse and shop vac it, sucks the water right out of the carpet, easiest method Ive used ever
Old    alan plotz (alanp)      Join Date: Apr 2001       08-01-2005, 6:19 AM Reply
i paid a carpet dude 30 bucks to clean my carpet.
Old    Matt VdA (mvda)      Join Date: Dec 2002       08-01-2005, 8:52 AM Reply
What Duane said, but with some spray on carpet cleaner in the mix too.
Old    Jeff Reese (jeffr)      Join Date: May 2002       08-01-2005, 9:11 AM Reply
What Duane said...
Instead of the regular hose… I run a hose from my hot water tank. Sprinkle some Oxy Clean powder around and start scrubbing. Smells nice once it’s dry. The hot water will also help clean out the bilge.
Old    David D (wakeguru)      Join Date: Feb 2003       08-01-2005, 9:23 AM Reply
If you don't have carpet cleaner or Oxy Clean, just use a little liquid laundry detergent mixed in water.
Old    Phil (mmobius2001)      Join Date: Jun 2004       08-01-2005, 1:02 PM Reply
i want to steam clean w/ carpet machine but havent had a chance, but all i do is vacumm, then use Blue Corral dri-clean, spray it where needed scrub it then re vacumm, smells nice and cleans nice.
Old    C.I.E. J-Rod (jarrod)      Join Date: May 2003       08-01-2005, 1:08 PM Reply
Flood your carpet. scrub. wet/dry shop vac.
Old    Stanfield (stanfield)      Join Date: Mar 2004       08-01-2005, 1:46 PM Reply
Rent a steam cleaner from the grocery store with the hand attachment. It works wonders. When finished, our carpet was a whole new color.
Old    John Marshall (johnm_ttu)      Join Date: Jul 2005       08-01-2005, 1:53 PM Reply
Depending on the level of filth you can get some great results with simple green. Use a pressure washer to remove the cleaner.
Old    King of PoP (troyl)      Join Date: Feb 2002       08-01-2005, 4:52 PM Reply
The Pressure washer here..stands the carpet back up too.
