Old    ricky (stunt3342)      Join Date: Jul 2005       07-28-2005, 3:07 PM Reply
i'm going fakie on my raleys and not getting full extension. any tips?
Old                07-29-2005, 8:49 AM Reply
Are you letting go with one hand? This will pull you toward that side of your body.
Old    Eric (ethomass)      Join Date: Apr 2005       07-29-2005, 10:46 AM Reply
I do the same thing as well. I found out that i was bringing the handle to my trailing hip. This would start to rotate me. When you are pulling the rope back in for your landing try bringing the handle towards your leading hip. This helped me be a little more consistant.
Old    ricky (stunt3342)      Join Date: Jul 2005       07-29-2005, 11:38 AM Reply
alright thanks i will def try that today
Old    alan plotz (alanp)      Join Date: Apr 2001       07-29-2005, 12:10 PM Reply
i think you are stargazing. weight the front foot more. and you wont rotate to fakie. if this is the problem. if you wanna land a crypt then pull the handle to the rear hip.
Old    Chuck H. (toesideturtle)      Join Date: Oct 2002       07-29-2005, 5:01 PM Reply
I was doing the same thing--easy fix. Think of keeping your weight equal on both feet as you leave the wake.
Old    ricky (stunt3342)      Join Date: Jul 2005       07-29-2005, 11:50 PM Reply
alright i'll def try that and tell u how it goes. thanks
Old                07-31-2005, 5:12 PM Reply
Try looking at the boat while your in the air, it will help to keep your body square and you won't stargaze.
Old                08-01-2005, 9:52 AM Reply
You have to much weight on your back foot most likely, you can always just land the krypt, i've never landed a krypt on purpose but have stuck several. Never give up, i've had the board completely to revert but have pulled it back.
Old    ricky (stunt3342)      Join Date: Jul 2005       08-01-2005, 11:20 AM Reply
finally get to go out today and try it. i'll tell u how it goes
