Old    Roddyrod (wakeslife)      Join Date: Jul 2005       07-28-2005, 11:55 AM Reply
Would it be similar to on a skateboard?? I tend to think the board would get away from you as you are being pulled by the boat and the board isn't.
Old    Jason Parmentier (xbar)      Join Date: May 2003       07-28-2005, 2:46 PM Reply
Since you are being pulled by the boat you will need to essentially push the board to where you will be landing. Make sure that you are set up, board is tracking flat and not on edge, bend your knees, and have at it. I have a friend who was able to do this switch on his first day. Definitely makes the landing a little more comfortable and easy to ride away from. But expect to fall a couple of times when trying and good luck.
Old    Roddyrod (wakeslife)      Join Date: Jul 2005       07-28-2005, 3:26 PM Reply
thanks ill give it a go!
