Old    Jamie Lokken (wakechic06)      Join Date: Jun 2005       07-23-2005, 4:16 PM Reply
Ive tried a couple methods but havent landed one yet. How exactly do you get the board turned the right way w/ out getting off balance?
Old                07-27-2005, 12:58 PM Reply
Check this out
Old    Small Light (stephan)      Join Date: Nov 2002       07-27-2005, 2:56 PM Reply
It's all about edging hard and then squaring up for a big vertical pop. you wanna take this as up as possible. Poke your front leg towards the shore your coming from and really think about pushing your back leg to the opposite shore. it's more back leg poke than anything. Definately the sickest grab to learn. Keep the handle in tight and you will be fine.
Old    Small Light (stephan)      Join Date: Nov 2002       07-27-2005, 3:00 PM Reply
Old    Professor (brhanley)      Join Date: Jun 2001       07-27-2005, 4:02 PM Reply
I personally think that the better methods are kicked out with the back foot and not so much with the front foot. That is more snowboard style and more appealing to me. The board should be almost perpendicular to the boat, so that you can see the entire bottom of the board and the tip and tail are basically equi-distant from the boat. My personal opinion. A few good examples:
And, one of my better attempts...I've had a hard time getting this trick and have only hit a few that have felt good. This is one of them:
I think that Heavy is right, though. Keep the handle in tight. I think about giving a tug with my back hand and even moving my hips towards the handle on the pop. I get into trouble when I try to throw it too soon. Get your pop, then go for the poke. I also think that you'll see from the pics, especially the first one, that the front leg is not poked. Its pulled up to the chest and twisted. Good luck.
Old    Small Light (stephan)      Join Date: Nov 2002       07-28-2005, 1:11 PM Reply
I agree, the picture I posted above is certainly not my best method. It's a hard one to really get right. I notice that when I do get one right my back is arched out over the edge of the board. brian in your pic if you were to arch your back and poke your back leg more you would have it perfect.
