Old    Dennis (dennish)      Join Date: May 2005       07-25-2005, 11:48 PM Reply
How would you weight a v215 for wakesurfing. Have triple ballast stock. Where should I add weight to surf goofy foot?
Old    Larry Mann (niap101)      Join Date: Jul 2004       07-26-2005, 7:53 AM Reply
See the post:
http://www.wakeworld.com/MB/Discus/messages/87668/242400.html?1122339751
for info and pictures on goofy side ballast. You are likely to need to fill the ballast on the right and the front ballast. You may need additional weight. The easiest way to test this if you don't have fat sacs is 30 gallon plastic garbage cans. They weigh about 250 pounds when full of water and can be returned for a refund when you are through with them. For testing weight in lockers, 5 gallon buckets weigh about 40 pounds each. One of the keys to building your ideal wake is to test. Test numerous configurations and then try to fine tune it. For additional ballast info, go to:
www.HowToWakeSurf.com and read the section on ballasts.
Old    Dennis (dennish)      Join Date: May 2005       07-26-2005, 6:50 PM Reply
Thanks Larry. I guess that trial and error is the best method. Anybody know how much weight the Sanger triple ballast is when filled to capacity?
Old    Clinton (just_board)      Join Date: Jul 2005       07-27-2005, 9:56 AM Reply
a gallon of water weighs 8 lbs.
