Old                07-25-2005, 9:28 AM Reply
if you doing invert tricks or whatever. do u recoomend keepong the fins on your board? what are some pros and cons?
Old                07-26-2005, 4:17 PM Reply
unless your doing sliders or practicing alot of surface tricks i'd say keep your fins on
Old    Small Light (stephan)      Join Date: Nov 2002       07-26-2005, 5:26 PM Reply
Some boards have molded fins and it allows them to track well without the center fin. It will ride like a normal board just looser. Fins provide tracking and that is good. Unless you are advanced and have great control & a board with molded fins I'd leave the things on there.
Old                07-27-2005, 10:22 PM Reply
im fine at riding it and carving but is there advatages when you land the trick with fins on?
Old    Small Light (stephan)      Join Date: Nov 2002       07-28-2005, 2:15 PM Reply
depends on the trick, if you have plenty of control finless then why switch? Fins can have a tendency to straighten you out too fast and a finless board is able to slide into position easier, on the flipside this can work against you too.
