Old     (wakeboarder84)      Join Date: Jul 2005       07-16-2005, 8:35 PM Reply
when i was learning a 180, i had the worst issues with keeping on axis. no matter what my feet always came out from under me...is it just me or am i doing something wrong?
Old     (tyboarder03)      Join Date: Nov 2003       07-16-2005, 9:16 PM Reply
Grant
Ive been having the same problems, i can land 180's w2w sometimes, but not even close to consistant, I've heard try to keep the rope close to your hips, but im not sure, Ive already in the last 2 weeks stuck backrolls consistantly, and almost tantrums, but im pissed that something like a 180 can just completely dominate me. Your not alone.
Any helps appreciated.
~Tyler~
Old     (wakeboarder84)      Join Date: Jul 2005       07-16-2005, 9:19 PM Reply
way off subject, but whats the difference between a backroll and a tantrum?
Old                07-17-2005, 4:33 PM Reply
for a 180 you want to be at the peak of your heigh then pull the handle in with both hands to your back hip to initiate the rotation and to stay on axis. if you are getting off axis its because you are letting your arm(s) out and/or pulling in and trying to spin right off the wake.
Old     (denwakebdr)      Join Date: Apr 2004       07-17-2005, 10:57 PM Reply
Grant, Try picking a spot on the shoreline and looking at it..see if that helps
Old     (alanp)      Join Date: Apr 2001       07-18-2005, 8:09 AM Reply
tantrum- backflip
backroll- board rotates behind you
try your 180's one wake first before going w2w(wake to wake). if you cant do them one wake then ur not gonna be able to do them w2w. get pop and then rotate and look at the shore.
Old     (rmack)      Join Date: Jul 2005       07-18-2005, 9:15 AM Reply
Don't look down and keep the handle at your hip. I had the same problem with the 180's and that helps me.
Old     (kawaik)      Join Date: Feb 2005       07-19-2005, 4:31 PM Reply
i am in the same boat (figuratively). i can land backrolls and tantrums but spins have me whooped. i am closer to landing a toeside roll to revert than a heelside 180. wtf?
Old     (kawaik)      Join Date: Feb 2005       07-19-2005, 4:33 PM Reply
btw i can do them over one wake but w2w i over rotate or come off axis and get kicked in the mouth for it.
