Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through July 21, 2005
Old     (petertjr)      Join Date: Sep 2004       07-08-2005, 10:04 PM Reply
hey people, i know there is a trick tips section but i need lots of feedback as soon as possible, so i hope you don't mind me posting here. I have been landing the tantrum on and off all season, not that i am getting the the trick really high i can't land it anymore, i think i may be over rotating. Any tips to help me master this? i'm competing for the first time in wakestock this year. thanks
i also can't seem to make the handle pass when trying a 360, i spin fine, but can't get the handle
Old     (petertjr)      Join Date: Sep 2004       07-08-2005, 10:07 PM Reply
that was supposed to say now that i am getting the trick really high!, my bad lol
Old    dbritto1977            07-08-2005, 11:47 PM Reply
R U iding a different board? Iam this year and dont like it...boards too slow to last year....if notthen dont cut out as far cut out about 1 - 2 Ft less then when your orver rotating.... but throw it the same as you would....... 360' no help there... Sorry
Danny
Old     (thane_dogg)      Join Date: Jun 2002       07-08-2005, 11:51 PM Reply
keep the handle in. If done correctly you rotate around the handle, and you can use the handle to speed up, slow down, or stop your rotation.
On your 3, the spin is half the battle. If you can ride away from it with no handle then you're half-way there. Cut as soft as you can and still clear the wake, pump the wake and take the trick straight up, give the handle a slight tug with both hands and pass it. The edge is the key.
For a while I thought I was edging soft enough, and then I rode with someone who told me I still needed to edge softer.
Old     (malibuboarder75)      Join Date: Jan 2004       07-09-2005, 10:37 AM Reply
Another thing with the handle pass. You have to pull the handle to your other hand. You can't try to reach for the handle to make the pass. If you try to reach for the handle to make the pass, you will fall off axis and bite hard.
