Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through June 19, 2005
Old    Matt (praisinplaya)      Join Date: Aug 2001       06-15-2005, 7:33 AM Reply
Hey guys weve got a 96 Prostar 205 direct drive with about 800 lbs of lead thats split 40/60 front to back. The wake is really good size, but we have a problem, the drivers side of the wake (my heelside, i ride regular stance) is very rampy with practically no lip, while the other side is the perfect shape with a great lip. My question is what could be causing this and how can i fix it?! I have tried moving weight around and putting more on the drivers side, then more on the passengers side and nothing seems to help. Any suggestions?!? Thanks!
Old    Matt (praisinplaya)      Join Date: Aug 2001       06-15-2005, 7:36 AM Reply
oops sorry guys...meant to post in the boats section
Old    drewsky24            06-15-2005, 9:27 AM Reply
Put more weight on the passenger side and take some away from the drivers side. Post a pic of it when you get a chance.
Old    gruelie            06-15-2005, 9:28 AM Reply
You just need to even the weight out. If the driver is heavier than the other passengers than the wake will be different
Old    Jonathan Metherell (jonm)      Join Date: Jan 2002       06-15-2005, 11:34 AM Reply
Make sure the weight is even side to side in each section of the boat as well (front, middle, back). I have had it wher I can move weight side to side in the back of the boat and not fix the shape. Try moving the weight side to side in the front too as the problem could be up there.
Old    Big Ed (big_ed_x2)      Join Date: Jul 2004       06-15-2005, 12:39 PM Reply
I noticed that if the weight is uneven in the front,it effects the wake ALOT more then the uneven weight in the back.
Old    Matt (praisinplaya)      Join Date: Aug 2001       06-16-2005, 6:48 AM Reply
thanks guys i'll try to move some of the lead in the bow around this afternoon and see if it will even out . ill also try take a pic if i get a chance
Old    John Anderson (fly135)      Join Date: Jun 2004       06-16-2005, 7:05 AM Reply
The rotation of the prop causes the one side of the wake to be problematic. 480 lbs of weight in the back of a 205 is not enough. You will need more weight in the rear to overcome your wake issues.
Old    Matt (praisinplaya)      Join Date: Aug 2001       06-16-2005, 8:12 AM Reply
Hey John (and everyone else) what would be the perfect weight set up for the largest wake possible? Ive got tons for fat sacks and stuff sitting on the storage unit....just wondering what everyones thought would make the best wake?
Old    Big Ed (big_ed_x2)      Join Date: Jul 2004       06-16-2005, 8:55 AM Reply
In a 205,I believe go 60 to 40 bow to back.60% of the weight in the bow and 40% of the weight in the back.That is especially in the winter when everybody sit in the cockpit.You can't go wrong if you go 50% to 50% distribution from front to back and at least put 1000lbs over the stock.
