Old    Tom Murphy (murphytj)      Join Date: Mar 2003       06-07-2005, 9:50 AM Reply
I picked up 2 3 blade 13X13 LH 1" bore props at a garge sale, my boat takes a 13X13 LH 1 1/8" bore. Has anyone ever had a prop resized? I don't think it would be difficult for a machine shop to do, but was curious if it had been done before. Thanks Tom Murphy
Old    Trace (trace)      Join Date: Feb 2002       06-07-2005, 10:12 AM Reply
i'd be shocked if they had different castings for the same props, so it should be cake for a machine shop to rebore & broach a prop. they will charge more for SS than nibral if they know what they're doing.
so what kind of deal did you get on them?
good luck.
Old    NAW (ripr)      Join Date: Mar 2002       06-07-2005, 10:24 AM Reply
Cutting it isn't bad, the set up is a little bit more trick. Might be hard to find somewhere to chuck on. May have to deepen the keyway as well.
Old    Trace (trace)      Join Date: Feb 2002       06-07-2005, 11:02 AM Reply
i'd think chucking on a 3 blade shouldn't be much of a problem. 4 blade would be tougher.
Old    NAW (ripr)      Join Date: Mar 2002       06-07-2005, 11:04 AM Reply
True. I'm not sure how much a small shop would charge.
It'd probably cost more than a new one for my shop to do it.
(Message edited by ripr on June 07, 2005)
Old    Mikeski (mikeski)      Join Date: Aug 2003       06-07-2005, 11:10 AM Reply
Any good prop shop can do it, figure $50+/-
When I dropped my prop off I mentioned to the guy that I had to get rid of my old spare because it had the wrong shaft size, he said "you should've brought it in, we can open up the shaft bore"
Old    Tom Murphy (murphytj)      Join Date: Mar 2003       06-07-2005, 1:09 PM Reply
Thanks,
I will call a couple prop shops and see what they charge. I paid $60 each, so can still come out ahead if it is not too much more. They are both brand new still in the box OJ legend- Nibral. They are a few years old but other than that look fine.
Old    Bruce Banner (breadbutta)      Join Date: Dec 2003       06-07-2005, 5:31 PM Reply
Be aware, the bore is reduced from one end to the other. It's not a straight bore, it's conical.
