Old    Ed (skinautique2001)      Join Date: Apr 2005       05-05-2005, 11:48 AM Reply
I want to mount some speakers on my skylon fat pole (3" dia). Any suggestions on mounting brackets/configuration?
Old    Preston Hall (phall925)      Join Date: Feb 2005       05-05-2005, 1:36 PM Reply
You can fabricate one. My neighbor did and I will send you some pics in a week or so when I get some. Also I just made a set for a friend. There was a skylon mount on here ini the classified ads and I just bloted some cans to the mount and that was that. Try contacting skylon becasue they made the bracket that I bought off the guy on WW
Old    Adam Curtis (acurtis_ttu)      Join Date: May 2004       05-05-2005, 4:04 PM Reply
you can find everything you need at home depot. I used 1 7/8 inch galvinzed pipe paintied black and some large u-bolts painted black. I clamped the cans to the pipe. I had to use a rubber pipe connector (3 inch) to stop the u-bolt from sliding down the pole in rough water
Old    HYPO (hypo303)      Join Date: Jun 2004       05-05-2005, 4:11 PM Reply
i mades some cans out of a 6" pvc coupler
then i bought some 8' L brackets , i mounted a L bracket on each side of the pylon ,i drilled a hole threw the pylon then i mounted the speakers on the bracket
pylon
Old    Gordon (rake)      Join Date: Jun 2003       05-05-2005, 8:08 PM Reply
I've got a set of quick disconnect wake tubbies (6-1/2") with the bracket for a extended pole I no longer use. Here is a pic of the pole & bracket, if you're interested I can get a pic of the speakers this weekend.
speaker bracket on pole
Old    pbilt024            05-28-2005, 9:44 PM Reply
Gordon, Do you still have the board rack, and if so do you want to sell it?
Old    deeslicious            06-06-2005, 3:42 PM Reply
Gordon, do you still have the speaker mounts and rack? Would really like to buy!
Old    882001 (882001)      Join Date: Nov 2003       06-06-2005, 4:38 PM Reply
http://www.wakeworld.com/MB/Discus/messages/65921/195989.jpg
Old    deeslicious            06-07-2005, 12:11 PM Reply
882001 - do you know how I can get a hold of those speaker racks? Are they for sale? CAll me @ 805-886-8318 with any info if you don't mind.
Old    882001 (882001)      Join Date: Nov 2003       06-07-2005, 1:12 PM Reply
i got tower speakers and had that size pipe welded to the pole. it was the cheapest route
Old    deeslicious            06-07-2005, 2:18 PM Reply
did you go with aluminum, or what kind of pipe is that?
