Old    Dave Shipley (dss)      Join Date: May 2005       06-01-2005, 9:12 AM Reply
I just purchased the Fusion 3-way combo speakers and my question is, what Ohm load are these speakers seeing? 4 ohms or 2 ohms? If 4 ohms, how do I wire them up to see 2 ohms using the supplied crossover?
Thanks
Old    Alpha_Beast (socalwakepunk)      Join Date: Dec 2002       06-01-2005, 9:22 AM Reply
2ohms
Old    Dave Shipley (dss)      Join Date: May 2005       06-01-2005, 10:21 AM Reply
Thanks!....
So if I have an amp that is rated 150W X 2 @ 2ohms, each driver will get about 75W each?
Old    Alpha_Beast (socalwakepunk)      Join Date: Dec 2002       06-01-2005, 10:32 AM Reply
I guess so. Mine came with x-over built in (installed in the enclosure). Measuered impedence @ 2ohms (single pair of terminals for the whole speaker combo). Running 250w x 2 @ 2ohm (PPI 1000.4) per speaker combo. Works really well.
(Message edited by socalwakepunk on June 01, 2005)
Old    Jason Pribyl (skibum69)      Join Date: Aug 2004       06-01-2005, 10:44 AM Reply
actully, if I am not mistaken, if the amp is rated for 150 X 2 it is putting out 150 watts to each channel.
Old    Dave Shipley (dss)      Join Date: May 2005       06-01-2005, 10:56 AM Reply
Great!.... Yeah, mine also came just like yours with the x-over installed in the enclosure & the single pair of terminals. I just wasn't sure of the impedence. (I'm not very stereo savy)
I was actually thinking of getting a new PPI just for these combo's. Thanks again!
One more question, I was thinking of putting a switch on the 'Remote' wire running to the amp powering the tower speakers to be able to turn them on/off...... Would this work?....
Old    Alpha_Beast (socalwakepunk)      Join Date: Dec 2002       06-01-2005, 11:29 AM Reply
Dave - I don't see why not, sounds like a good idea.
Old    Tallredrider (talltigeguy)      Join Date: Sep 2003       06-01-2005, 11:37 AM Reply
Dave,
I think it would be even better to put a LC1 knob on the RCA jacks to your amplifier and then rather than just turning your tower speakers on and off, you can adjust the volume precisely. I have one and it is not difficult to install, and works beautifully.
Do a search for LC1 and you'll find lots of info.
Old    Alpha_Beast (socalwakepunk)      Join Date: Dec 2002       06-01-2005, 11:57 AM Reply
Even better. The Clarion remote is so close to the drive in my boat, it's all too easy just to turn the volume down when the rider drops.
