Old    Matt (flyspec14)      Join Date: Apr 2005       05-31-2005, 11:23 AM Reply
Alot of guys use these when towing campers, but does anyone use one to pull there boat? Here's what I'm talking about:
{url}http://www.stylinconcepts.com/part.cfm?PartID=487282&PartFamilyID=1529&SubCatego ryID=190&CategoryID=29
I'm really trying to get the ultimate towing set-up for my DROPPED GMC. Thanks for any input!
Old    Phatboypimp (phatboypimp)      Join Date: Apr 2005       05-31-2005, 11:37 AM Reply
I used to sell these weight distributing hitches and I had one for a 32' trailer. In my opinion it would be overkill, depending on the size of your boat. If you are pulling something over 30' I would recommend it. If you are looking to keep your truck balanced and level for a traditional ski/wake boat, I would use airbags as the distibuting hitches are built for much heavier tounge weight and wont make a big difference.
Old    Andy Hummel (sparks426)      Join Date: Dec 2003       05-31-2005, 11:58 AM Reply
Most boats are pretty well placed on the trailer to provide a certain amount (and relatively light at that) of tongue weight. Load-leveling hitches are typically required for a camper, especially when you start loading them up and the tongue weight goes way up.
Old    Alpha_Beast (socalwakepunk)      Join Date: Dec 2002       05-31-2005, 11:59 AM Reply
I use the WD hitch at work, when I tow 9000lb + diesel generators. Not needed for the SAN. Ditto what Jason says about the airbags - especially on a dropped vehicle. Watch out for shallow launch ramps...
Old    Matt (flyspec14)      Join Date: Apr 2005       05-31-2005, 12:53 PM Reply
I already run bags, I'm just looking to reduce the rear bouncing a bit
Old    Wakejunky (wakejunky)      Join Date: Apr 2002       05-31-2005, 4:29 PM Reply
Actually, with the use of surge brakes on these trailers alot of the manufacturers will not recommend WD hitches.
I know the surge brakes that DHM use, UFP, allows the use of WD hitches.
Check with the surge manufacture and/or trailer manufacturer.
But, in all reality our boats are light in comparison to travel trailers so, there really isn't much need.
Chris
Get the Grip you Deserve
www.wakejunky.com
