Old    JT (aidan)      Join Date: Feb 2004       05-21-2005, 9:39 PM Reply
Got major feedback noise out of speakers especially at low volume. When turned up it drowns out the noise. Got 2-800.4 Kickers with 1200.1 Mono. I've got good grounds, the deck is JBL marine. Does filter really work. The noise is bad?
Old    Alex Benetatos (calabria_man)      Join Date: Aug 2004       05-22-2005, 6:31 AM Reply
check your RCA's
Old    mia            05-22-2005, 8:10 AM Reply
are you splitting the rca's or have a crossover in the line ?
Old    Peter_C (peter_c)      Join Date: Sep 2001       05-22-2005, 10:46 AM Reply
As said above disconnect the RCA's and see if the noise changes. The noise can come in through the power feed wires also, like if they are run near a coil, tach lead, alternator etc.
Old    JT (aidan)      Join Date: Feb 2004       05-22-2005, 4:39 PM Reply
That is funny you said RCA's, the speakers on the right side under dash stopped working. I pulled RCA's and pluged back in and they started working. The RCA's are split so I think they might be bad. Should I change them all to something high end?
