Old    highrider (highrider)      Join Date: Nov 2001       05-18-2005, 9:42 AM Reply
I need to locate my heater core in my 2000 X-star? Never had to mess with it much, and I believe it's time for a new one.
I suspect a leak in it, and my heat hasn't been too hot!!
Any info would be great before I go blindly lookin for it.
THANKS.
Old    Migitty Matt (migitty)      Join Date: Aug 2001       05-18-2005, 12:12 PM Reply
Most likely, it's underneath the starboard bow seat cushion.
When they leak, you know. Your boat starts to fill with hot water.
I have replaced at least four in mine. It's pretty easy. You will need a rivet tool and drill.
Old    highrider (highrider)      Join Date: Nov 2001       05-18-2005, 12:30 PM Reply
Thanks Matt.
Under the floor, correct?
Never tried to remove the floor panel. Is it just screwed in from the top...or????
Old    Migitty Matt (migitty)      Join Date: Aug 2001       05-18-2005, 2:01 PM Reply
No, under the seat cushion. Towards the rear of the compartment. It's a metal box with two wires and two hoses (probably 12" x 6"). Not under the floor panel at all. If that's not where it is, just follow the hoses that the heat comes out of or the hot water hoses running from the engine.
Old    cdm (cdm)      Join Date: Aug 2003       05-18-2005, 8:58 PM Reply
its been awhile, but I think its starboard infront of the driver. look up under the bow seats
Old    Big Ed (big_ed_x2)      Join Date: Jul 2004       05-18-2005, 10:43 PM Reply
should be under the dash!
Old    cdm (cdm)      Join Date: Aug 2003       05-19-2005, 12:58 PM Reply
yes under the dash drivers side
Old    highrider (highrider)      Join Date: Nov 2001       05-19-2005, 1:05 PM Reply
yup...dug it out from under the dash....behind the kick panel at the drivers feet! Thanks for the help folks!
Old    highrider (highrider)      Join Date: Nov 2001       05-20-2005, 5:41 AM Reply
Got a replacement heater core from Auto Zone for $15.99...and it has a lifetime warrenty. Can't beat that!
You don't even want to know what a marina charges for the core....
Thanks again!
Old    Peter_C (peter_c)      Join Date: Sep 2001       05-20-2005, 7:40 AM Reply
The reason many people are having high failures is because the hoses are not being properly supported. Make sure there is no pressure on the hoses in any direction.
