Old     (hyperlink)      Join Date: Nov 2003       05-18-2005, 6:19 AM Reply
My prop got bent up the other day and i dont know if i should get the same one from the factory, or if there is something else out there that will work better. I have an 04 Tige 22v with 1400lbs of ballast and i usually have a minimum of 5 people in the boat. I have heard things about different props making the wake change. Please help me out, i am going to buy one this week and want only the best. Thanks
Old     (hyperlink)      Join Date: Nov 2003       05-18-2005, 8:52 AM Reply
anyone??
Old     (breadbutta)      Join Date: Dec 2003       05-18-2005, 9:33 PM Reply
Not so much making the wake change as the ability to match a proper RPM/Torque from the engine to the perfect speed for the wake you like. http://www.acmemarine.com/html/list.html I just picked up a model #515 from boarditup. It is a 13x12 LH. My original was a 13x14 LH, so i should get more low end power and the top end will be a bit slower. I run about 1600 lbs of ballast and was having a porpoising problem (the perfect pass would alternately accel then decellarate) Memorial day will be the first time we take it out.
Do your homework on what your needs are for this $300+ purchase.
