local tire shop will usually give you buckets of their used lead tire weights for nothing... melt into blocks and then coat with epoxy and you're done. also, you can buy used tractor weights 50-100# each from a salvage yard, coat them with epoxy and place throughout boat. be careful trailering with lead displaced in the boat. extensive wear on your bunks, brakes and trailer springs...
