Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through May 16, 2005
Old    Adrenaline Junkie (kgoings)      Join Date: Apr 2005       05-11-2005, 8:22 AM Reply
So I weigh 180 the 135 says 80 - 180 the 139 says 120 - 210 and the 143 says 150++
I have only ridden a wakeboard 2 times, are they more easy to turn on the smaller they are? Are they harder to get up on the smaller they are??
**EDIT Its the Free Motion DRIVE***
(Message edited by kgoings on May 11, 2005)
Old    toolfan (toolfan)      Join Date: Jul 2003       05-11-2005, 8:26 AM Reply
143
think about it. the difference is minimal. 135 to 143 is only 8 cm. 4 cm per side. that is less than 2 inches. the added weight will be nominal but more surface area to land on usually means softer and more stable landings(pending your form is good).
(Message edited by toolfan on May 11, 2005)
Old    C.I.E. J-Rod (jarrod)      Join Date: May 2003       05-11-2005, 8:29 AM Reply
Some will argue but bigger is better. Turning isn't a big part of wakeboarding. Bigger board will be easier to control and much easier to land. You would be fine on the 139. I personally would go for the 143.
Old    jeffsuperstar            05-11-2005, 9:09 AM Reply
would go for the 139.. bigger is always better
Old    Adrenaline Junkie (kgoings)      Join Date: Apr 2005       05-11-2005, 10:13 AM Reply
Thanks
