Old     (onealrep)      Join Date: May 2002       05-10-2005, 1:56 PM Reply
Looking for the stock prop spec's for an 03 V210. Banged mine up pretty good and need to replace. Haven't pulled it off yet to look at the spec's.
Old     (sam8)      Join Date: Dec 2004       05-10-2005, 5:30 PM Reply
Chuck,
Can't help on the spec, my 98 DLX came with a 13x13 OJ.
I had a conversation with Scott Pellaton from Sanger at the Sacto Boat Show, and they are now using ACME props because ACME's stuff is superior to OJ's in pretty much every way.
I do not know when they changed over.
If you find you have an OJ, I'd swap to the ACME. Do a search and you will find that there is a recent thread where some of the experts on here had a good discussion on this topic..
I am going to buy one sometime this summer.
Old     (ralph)      Join Date: Apr 2002       05-11-2005, 12:55 AM Reply
Are you running a lot of ballast Chuck? I push 1600-1800 pounds and have the Acme 525, can't imagine a better prop. Top end is only 44mph tho.
Old     (onealrep)      Join Date: May 2002       05-11-2005, 7:13 AM Reply
Thanks guys, I checked last night, it is a 13 x 13 OJ 4 blade. Bill at Acme recommends the 515 Acme 3 blade. I only run about 1000 pounds, and do quite a bit of cruising. Bill at Acme claims better holeshot and top speed with the 515. I'll be ordering one this morning!
Old     (chas)      Join Date: Feb 2002       05-11-2005, 9:25 AM Reply
The 515 is what came on my 05 V210, works well.
Old     (boarditup)      Join Date: Jan 2004       05-11-2005, 10:04 AM Reply
Got a refurb for $250, if you want it. New for $310.
Old     (onealrep)      Join Date: May 2002       05-11-2005, 11:56 AM Reply
Karl,
Thanks for the offer. My local shop has a refurb 515 as well, gonna grab it today.
Old     (guido)      Join Date: Jul 2002       05-11-2005, 1:17 PM Reply
If you are still looking..... Acme 13X12 4 blade is what worked best for my boat. It came with a 13X13, but the whole shot and top end is better with the 13X12. It actually got better gas mileage turning higher rpm's with less load, too and it never stops pulling. Ballast, people plus gear and my boat never has any trouble with pickup.
Old     (boarditup)      Join Date: Jan 2004       05-12-2005, 6:06 AM Reply
A bit of caution. Make sure the prop was refurbished with the Acme blocks, not the standard blocks. This is very important to performance and vibration. If you cannot verify that the Acme blocks were used, don't buy it.
