Old    bambamski            05-03-2005, 9:25 AM Reply
I'm having a couple of amps installed in my X-2 and would like some advice from some X-2 owners.
Did you have to install some sort of rack for the amps or did you just mount them to the Fiberglass under the glove box? It appears Mastercraft has built up or made the fiberglass wider there so they didn't have to put a rack in there.
I took a couple of pics but they didn't turn out.
Old    Jason Pribyl (skibum69)      Join Date: Aug 2004       05-03-2005, 9:40 AM Reply
I have a 205 which is pretty much the same under the passengers seat as the x-2 and I did racks. Pics would really help. But I think either way you will be ok.
Old    KG (iagainsti)      Join Date: Apr 2004       05-03-2005, 5:03 PM Reply
There is a thicker area to mount a second amp. As you stare into pass storage area the left wall that makes up your bow walkway has a 1x1 (approx) patch of thicker fiberglass. Just make sure to use smallest screws possible. Its right above the fire extingisher on my 01' xstar and my sub amp fit perfect. I also made a frame for a third amp along the bow.
