I noticed Friday that I have a small leak around the driveshaft, inside the boat. It looks lke the driveshaft is bolted to an output plate/shaft that comes out of the transmission. The driveshaft then passes through some sort of housing, which I assume contains some type of bearing/lube. At the top-most portion of this housing, there appears to be a cap that wraps around the driveshaft. Water is leaking around the gap between this cap and the driveshaft. I would assume this is just due to normal wear, and likely just needs some type of seal replaced. Anyone steer me in the right direction in getting this done, such as diagrams, instructions, etc? (Message edited by atropine on May 01, 2005)
