Old     (wakeboard19)      Join Date: Apr 2005       04-10-2005, 4:01 PM Reply
How is the wake on a 1994 maliub echelon wake.
Old     (sbt3)      Join Date: Jun 2002       04-11-2005, 6:23 AM Reply
The wake on the echelon is very nice. It is SV23 hull which is the same hull as the wakesetter. I have had 3 friends that have had them and they are one of my favorite wakes.
Old     (ttrigo)      Join Date: Dec 2004       04-11-2005, 6:01 PM Reply
I have a 95 with the same hull, and it throws a pretty good wake when it is weighted down. I use about 600 lbs in lead and sand, and it is pretty nice. not going to be "world class" by any means, but pretty good.
Old     (sbt3)      Join Date: Jun 2002       04-12-2005, 5:39 AM Reply
Thomas,
You just need more weight. You should be running around 1000-1200 in the rear and 600 in the nose. You would be suprised how nice of a wake it will be. Like I said before it is the same bottom hull as the newer wakesetters.
Old     (ttrigo)      Join Date: Dec 2004       04-12-2005, 9:05 AM Reply
I dont mean to hijack here Kyle.
Stan - Ideally, I would love to put all that weight in the boat, but having a closed bow, I have the storage filled with essentials, and we generally have at least 5 people in the boat at all times, so we are very limited on space. I am planning on adding about 200 more in lead, but that is about all the room I have now.
Old     (sbt3)      Join Date: Jun 2002       04-12-2005, 11:11 AM Reply
Thomas,
Yeah the boat does get a little tight when you start filling it with sacs. One of the guys I ride with uses the fat seat in back and puts a tube sac in the locker. I think you could probably get away with a fat seat in back and then put some lead/sand in the nose so it doesn't take up all the storage in front. That is the main problem in my mind with the older ski boats and why I finally upgraded this year to a v-drive.
Old     (ttrigo)      Join Date: Dec 2004       04-12-2005, 1:35 PM Reply
I have always been worried about putting too much weight in it, since the boat sits so low anyways. I did not want to risk anything. I have a fat seat at home. I will try it out next time out, and see how it works out. just a matter of sorting out everything in the bow also.
Old     (wakeboard19)      Join Date: Apr 2005       04-12-2005, 6:14 PM Reply
Do any of you two happen to have pictures. thanks
Old     (wakeme884)      Join Date: Jul 2004       04-12-2005, 9:30 PM Reply
my friend had a 94 and we used one 600# sac between the engine and rear seat. Worked great, real nice wake. Plus spotter(s) could sit on sac facing backwards, real comfort and adds more weight.
Old     (sbt3)      Join Date: Jun 2002       04-13-2005, 5:44 AM Reply
I found a couple of pics from my friends boat. He has the fat seat in the back and a tube sac in the nose.
Old     (john)      Join Date: Apr 2002       04-13-2005, 10:07 AM Reply
May want to also post your questions at http://www.themalibucrew.com/forums/.
Old    tommyadrian5            04-13-2005, 9:37 PM Reply
a guy i ride with has a 95, I assume its the same hull
he normally has a 350lb sac in the ski locker and the wedge, good hard but steep wake
otherwise he puts 1200 in the rear and 300 in the front, no wedge, big, solid, vlx like wake
Old     (sloboat)      Join Date: Feb 2003       04-23-2005, 1:30 PM Reply
Stan
That wake looks nice!
How did the boat drive with that much weight?
Old     (sbt3)      Join Date: Jun 2002       04-25-2005, 5:40 AM Reply
Steve,
That was a fat seat, pretty full probably 1000lbs which was in the back and then a tube sac 350lbs in the walk way plus 4 people. The boat drives fine with that much weight, of coarse I am kind of biased because everyboat I drive is usually pretty loaded down.
