Old    Erik (erik_c)      Join Date: Jan 2005       04-01-2005, 11:34 AM Reply
I have a 2000 x-star and the rear hatch is one peice and opens with a large electric actuator on the passenger side. My problom is that I want to put a sac in there for surfing but I don't know if It would break the actuator, just wondering if any one has tackled this problom before any help would be awesome thanks.
Old    Wilson Lee (leewilson)      Join Date: Sep 2002       04-01-2005, 3:49 PM Reply
Erik
I have the same year and model and my actuator has been on the fritz. I usually have 2 400lbs fat sacks on each side, one laying on the actuator which may be a reason why is is on the blink. If your actuator goes out, you are hosed because you won't be able to open your hatch except through the seat, but you have a fat sack blocking it. My solution is that I bought the shocks and hardware to change it to a manual lifting hatch. I also bought some hardware to rig the release pin so I can pull the pin from under the seat. Just my thoughts...
Old    Brendan (kybool)      Join Date: Aug 2004       04-01-2005, 4:36 PM Reply
I have an actuator on my 95 SS Nautique and I put a fat sac in with it no problem. The fat sac just fills up around it. I have had absolutely no problems.
Old    Erik (erik_c)      Join Date: Jan 2005       04-01-2005, 5:29 PM Reply
Ive been thinking about just disconecting the thing and laying it on the floor, but do you think the hatch would fly open or is it to heavy I realy just want it for surfing so we will be doing 10 miles an hour so it should be ok
Old    Wilson Lee (leewilson)      Join Date: Sep 2002       04-04-2005, 8:25 AM Reply
The hatch wouldn't fly open going that slow, but it is a bit of a hassle to pull the pin when you want to.
Old    JK (xbrdr1)      Join Date: Feb 2003       04-04-2005, 11:30 AM Reply
I've been using the 550 on it for a couple yrs. No issues. Wilson raises a good point about not being able to get to it. You should 'rig' some sort of method of disconnecting the pin if the motor fails.
