Old     (skibum69)      Join Date: Aug 2004       03-31-2005, 7:02 AM Reply
Has anybody polished their aluminum cans? I was working with mine lastnight and the saw blade got gummed up with aluminum and even though I had them wrapped in bubble wrap, the pounding of them up and down scratched the bottom. So I need to buff them and wondering if anybody has done this and what they used. Thanks
Old     (biz)      Join Date: Mar 2004       03-31-2005, 9:29 AM Reply
Home Depot sells a kit.. you need a polishing wheel and some polishing rouge. It is easier to do when it is warm outside as heat plays a big part in the polishing of the part. Be forewarned, it does take time. Also make sure you don't have a clear coat on it, it may not match the other can(s) if you take the clear coat off of only only one of the cans.
Old     (bummerkit)      Join Date: Apr 2003       03-31-2005, 9:42 AM Reply
i usually recycle aluminum cans...
Old     (mikeski)      Join Date: Aug 2003       03-31-2005, 10:13 AM Reply
sounds familiar...
I bought a cotton wheel and put it on one side of my old grinder. I have been using it to polish some brackets I made out of aluminum angle. You probably need to first sand out the rough spots if there are any, use a fine emery cloth. Next use a stiff wheel and a heavy rouge to do the rough polishing. Finally you can hand polish out the machine marks using a cloth diaper with Mothers or Hapich Semi-Chrome coupound. If you take your time and work the process through the cans will look better then new, waaay better.
Old     (antbug)      Join Date: Jul 2004       03-31-2005, 10:31 AM Reply
get ready to get dirty... really dirty
Old     (sbt3)      Join Date: Jun 2002       03-31-2005, 12:24 PM Reply
At one point I polished a ski pylon that was in my boat. I wet sanded it with 1500 then used mothers aluminum polish. It worked pretty good. I guess it depends on how deep the scratches that you have are. The mothers aluminum polish works pretty well, I would try that first. I also used it on my board racks to get rid of some of the water stains. Here are a couple of pics of the pylon I did.
Old     (skibum69)      Join Date: Aug 2004       03-31-2005, 12:32 PM Reply
thanks for all the help, I'll try just polish first since they scratchs aren't deep.
(Message edited by skibum69 on March 31, 2005)
