Old    Tdc_worm C (tdc_worm)      Join Date: Sep 2002       03-23-2005, 6:29 PM Reply
need a little help here, i think i have this figured out, but i am not certain as I dont know a whole lot about preamps...
below is a schematic of what I am trying to do. The hull speaker amp will run off of the front channels. The tower speaker amp will run off of the rear channels so that I can use the fader to regulate the tower speaker volume. The sub amp, of course, will run off of the sub channel.
Here is where it gets a little tricky. I want to run an auxiliary plug for an MP3 player off of the auxiliary inputs as pictured.
My head unit (clarion XMD3, I think) has two sets of PreAmp out puts (front & rear).
My questions are:
1. How do I wire my head unit to the PreAmp when I only have one set of inputs available and two sets of PreAmp outputs (front & rear) to use?
2. Will I be able to use the fader as a “volume control” for the tower?
3. How do you think this will affect the sound of the system?
4. Is there a better way to do this?
BTW, the pictured PreAmp is a Clarion EQS744…
Old    Kenny (ghostrider_2)      Join Date: Aug 2004       03-23-2005, 9:16 PM Reply
I have the same EQ and that is how it is run I also run my MP3 player that way..you use the fader on the EQ for the tower/in boat speakers so that the tower can be blast'in for the rider but the volume in the boat isnt killing the passangers.
Old    bobbymucic            03-23-2005, 10:15 PM Reply
I'll add my 2 cents, although there are plenty of people more knowledgeable than me here that can offer better help.
Use the front or rear outputs from your head unit. Doesn't matter.
2. Will I be able to use the fader as a volume control for the tower?
No, not the fader on your head unit. Use the fader on the EQ instead, it will fade the tower and boat speakers. You will get no control over the boat speakers individual levels (front/rear, since they will be on the same output channel from your EQ. Adjust your gains well!
Should sound great. Like I said above, you might have to play with the interior speaker gains to get a good sound, since some speakers tend to sound louder than others. But the line driver aspects of the EQ will help clean the signal up, and having the subwoofer control is going to be a big bonus.
You could run the other head unit output directly to an amp (front or tower) This would allow you to use the fader on the head unit, and the fader on the EQ. However, you will have to set your crossover points on the amp (if you have them), and you will not get the pre-amp voltage boost that the EQ offers on that direct connection. Is it a better way? I don't know how it will affect the sound overall, it will just give you more "tuning" options.
Old    Preston Hall (phall925)      Join Date: Feb 2005       03-23-2005, 10:33 PM Reply
OK am an amature but I hav had my share of problems.( One of my buds works in a stereo shop and he ends up fixing or telling me whats going on).
I will tell you this, I know, either the XMD 3 has an AUX input to plug into the unit or you can buy a module to make an AUX input through the CNET bypassing all problems that you would have with the EQ that you seem to have.
If you would like more inof email me at reston@phall.org">preston@phall.org. I have no problem explaining the easy way out becasue I know you possiotion on this issue
later
Preston
Old    Mikeski (mikeski)      Join Date: Aug 2003       03-23-2005, 11:24 PM Reply
You have show exactly how my new boat will be done. Just hook the pre-amp to the front outs from the deck. Fading between the tower and boat will be done at the pre-amp. Now you will have two options for aux in, either through the deck or directly to the pre-amp. My XM will be through the deck and my MP3 will be direct to the pre-amp.
Niiice.
Old    Tdc_worm C (tdc_worm)      Join Date: Sep 2002       03-24-2005, 7:09 AM Reply
so just to verify two things--
-i wont lose any of the sound coming from the rear channels of the head unit if i only hook up the front RCAs to the PreAmp...
-what would be the effect of using the speaker level inputs on the PreAmp vs the RCA inputs?
Old    Louis Teague (loux2)      Join Date: May 2004       03-24-2005, 8:44 AM Reply
TDC, I have been strugling with this as well. If you only plug in the front chanel RCA's wont you lose sound? What do you do with the rear channel? This insecurity has kept from purchasing a line driver or an EQ. Although I want to get one. It just doesn't seem to make since to not plug in all the RCA's from the deck.
Old    TR (biz)      Join Date: Mar 2004       03-24-2005, 12:31 PM Reply
You don't HAVE to use ALL the RCA's coming out of the deck. What you are wanting is a signal (L and R) to the preamp. Since this preamp has front/rear/sub outputs you will be gaining a sub level out and retaining the front and rear. And as others have posted you will lose the ability to control front/rear or in-cabin/tower speaker with the Head unit however you can fade with the preamp and gain up to 7 volts of preamp out on this model which will result in a cleaner signal to the amps.
Also... In general do not use the speaker level inputs (which this unit specifically does not have)if you can use RCA's, if you do this you are going backwards.... you are sure to get more distortion and you want to get away from this.
(Message edited by biz on March 24, 2005)
Old    alan plotz (alanp)      Join Date: Apr 2001       03-24-2005, 12:38 PM Reply
louis no there will not be any sound loss you just dont use the rear channel. i dont use my rear(i have a clarion eq/line driver) at all but if i want to add another amp down the road ill have an open channel to do so. you can also use the front rear fader to control the amount of volume to the front but you dont get any more sound by fading the channel all the way to the front(im using front since it sounds like you wanted to use that channel). to simply answer your question just buy the thing itll work for you great.
Old    P M H (caffeineguy)      Join Date: Apr 2004       03-24-2005, 12:53 PM Reply
TDC, Where did you get the MP3 plug?
Old    Clete (domin8)      Join Date: Mar 2004       03-24-2005, 7:28 PM Reply
Try this, use the side bar for your search
http://www.anglernet.com/web/maps/shasta1.htm
Old    Clete (domin8)      Join Date: Mar 2004       03-24-2005, 7:30 PM Reply
sorry wrong topic
