Old     (face_smash)      Join Date: Aug 2004       03-22-2005, 7:54 AM Reply
Hi there, im pretty sure the speedo on my 04 VLX is out! (its simple to adjust while you are moving) I also have perfect pass but i am unsure if that is correct also?? (it might be OK, but it just seems soooo fast at 21mph) Any suggestions on how to calibrate the clocks to the correct speed??? or how to cheque ot they are right??
Old     (rem_pss308)      Join Date: Mar 2004       03-22-2005, 8:17 AM Reply
You need to check it with a gps.
Old     (skibum69)      Join Date: Aug 2004       03-22-2005, 9:50 AM Reply
In my owners manual it tells how to calibrate them using a stopwatch and a salalom course. You should check your manual
Old     (poser007)      Join Date: Nov 2004       03-22-2005, 9:53 AM Reply
Well I thuoght this thread was about how to look good in a pair of speedos. Just don't do it
Old     (mikeski)      Join Date: Aug 2003       03-22-2005, 10:02 AM Reply
GPS, slalom course, or any two fixed points with a stopwatch.
5280 feet per mile, 3600 seconds per hour -> 20 mph = 29.33 feet per second
Old     (face_smash)      Join Date: Aug 2004       03-23-2005, 7:19 AM Reply
Thanks guys, and Daniel use your imagination on how to look good in a pair of speedo's! ha ha
