Old    Dale Zurbay (dzurbay)      Join Date: Mar 2005       03-15-2005, 7:46 AM Reply
Hello, I bought an Air 216 last year. Wakeboard a lot, but still like a Sl set and a little barefooting so did not make the leap to a vdrive. I used the ballast (400lbs) plus 4 100lb dumbeels for awhile last year, but the dumbells move too much. Any other good non-fat sack options? I have heard people using Lead bars/blocks, but can't seem to find any vendors. Also would like to know if anyone has a good configuration (ex 200lbs in the front, 400 lbs in the back locker, and the ballast full = good) thanks, Dale
Old    Baron Phillips (phil06140)      Join Date: Jul 2004       03-15-2005, 9:21 AM Reply
i used 8 5-gallon gas cans filled with water. it looked strange but it was easy to move them around and take them in and out. then if you want to you could put sand in them for more lbs. but this also takes up room in the boat, i only rode with a friend tho.
Old    clubmyke (clubmyke)      Join Date: Aug 2004       03-27-2005, 8:04 AM Reply
i use lead bags from pop products...they are great for getting the wake right were you want it..
Old    Antbug (antbug)      Join Date: Jul 2004       03-27-2005, 8:47 AM Reply
I 2nd the POP production bags. 40lbs each, easy to move, they come in great bags, and the Company stands behind their product. If your in Socal these are the ones to get.
