Old    Adam Curtis (acurtis_ttu)      Join Date: May 2004       03-14-2005, 11:49 AM Reply
Anyone know what the advantages are to running a 3 wire alt vs 1 wire? Seems like the 1 wire is alot simpler and easier to install. I have a 96 MC PS 190 w/ the 350 in it. Currently have a 3 wire. Will I run into any issues by switching to a 1 wire?
Old    Shawn (superair)      Join Date: May 2000       03-14-2005, 3:50 PM Reply
nope you should not have any problems. The only difference is a self exciting regulator. When you hit 700 Rpm the alt will automatically kick on. When I replave mine I'll go to a 1 wire, that is what I have run in the past.
Old    Adam Curtis (acurtis_ttu)      Join Date: May 2004       03-14-2005, 4:03 PM Reply
Thanks shawn, I thoguht that it would not be an issue. I actually just ordered the 135 amp alt. from the guy you posted about. He helped explain everything. I was trying to over-complicate it. He said he doesn't even reccomend putting a circuit breaker on it. He said on a two battery setup hook the main power lead to the postivie terminal on your starting battery. As long as you have an inline fuse protecting the amps I'll be ok w/o a circuit breaker.
Old    Shawn (superair)      Join Date: May 2000       03-14-2005, 4:07 PM Reply
Yeah I just put one on just to be anal about it. I'm glad he hooked you up. You will love the new alt. If you have anyother questions just give me a holler!!
Old    Adam Curtis (acurtis_ttu)      Join Date: May 2004       03-14-2005, 4:19 PM Reply
what voltage are you seeing @ idle w/ all accesories off? He said the regualtors are set @ 14.2.
I don't understand how they can make them that cheap and not want a core back? I went to my local guy who built my 90amp, and said it would be around $200+ to rebuild one that big, and he wanted my core.
Old    Shawn (superair)      Join Date: May 2000       03-14-2005, 4:36 PM Reply
NO idea how he does it. I'm seing right at 14.1 on average. They are about bullet proof.
Old    tony burks (tonality)      Join Date: Mar 2005       03-16-2005, 1:32 PM Reply
Are these new 1wires you guys went with spark shielded for marine use? Where did you get them?
Old    Shawn (superair)      Join Date: May 2000       03-16-2005, 2:07 PM Reply
Yes. the guy is out of dallas.Look on ebay under marine alternators its a 1 wire that is 135 amps.
Old    Adam Curtis (acurtis_ttu)      Join Date: May 2004       03-16-2005, 3:36 PM Reply
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7961077953&catego ry=33573
Old    Adam Curtis (acurtis_ttu)      Join Date: May 2004       03-16-2005, 3:42 PM Reply
you won't find them anywhere cheaper...shawn said he's had no issues with either of his...I figure for a littel over a $100 its worth a shot.
Old    Bruce Banner (breadbutta)      Join Date: Dec 2003       03-17-2005, 5:40 PM Reply
Just be sure the unit is grounded properly.
