Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through April 01, 2005
Old    Flight007 (poser007)      Join Date: Nov 2004       02-20-2005, 10:06 PM Reply
What are the advantages of having double fins? Ive seen the boards that have four fins that look smaller then the normal two center fins. Im just curious what difference that makes?
Old    Show (bigshow)      Join Date: Feb 2005       02-21-2005, 5:23 PM Reply
I have a Liquid Force Trip 143. Six fins can be mounted on the board. There are four smaller fins at the extreme four corners and larger fins in the traditional center on each end of the board.
When you make a turn with the board edge the center fin often (all the time for myself) come out of the water adding no control benefit. So in hard turns the center fin isnít helpful. However, a fin on the out board edge deep in the water does help considerably.
My group of boarders havenít been using the center fin for quite awhile. Weíve found that the center fin doesnít help advanced riders. With the larger center fins removed itís easier to do surface spins. New riders probably need the center fins.
Hope that helps
Old    murrayair            02-22-2005, 1:02 AM Reply
The smaller fins help with tracking and allow you to customize the feel of your board, like Edward said. I've found that without the center fin, I can get away with bigger mistakes on landings because the board doesnt try to pull me around as much. But, on the other hand, with the center fin in I don't slip out as much on landing, which helps if I don't really feel like hanging on to the rope for dear life if I mess something up.
Old    Flight007 (poser007)      Join Date: Nov 2004       02-24-2005, 11:46 PM Reply
Thanks
