The Tower Box for the 209 is still under construction. I was told it would be done in time for Memorial Day weekend, but I doubt it will be done. It will house six Pioneer 6x9's (two forward/four back) and xenon tower lights. Should be pretty trick if we can ever get it done. Will post when pictures arrive.
Mike: cant you keep all the project's in order, LOL
Ok we are almost finished. Here is some photo's of the tower wired. Because the tower not olny folds down it also comes apart. Jason wanted it to be able to be fully diss-asembled. I needed to use a few quick dis-connect's, This was the first time I used the Neutrick Speakon line and pole connectors they worked great. How ever I wished I didnt need the double female connector's t make them work. There is a disconect at each joint and at the tower box. I used a water proof threw hull connector to run the wire's threw the top of the deck and into the tower
whitechocolate
Jon (2high4u)Join Date: May 2004
05-26-2005, 3:28 PM
Sorry it was a long weekend, the link above shows the XLR. Check Neutrik page for the female cable end part numbers. I belive parts express sells them........
