Old    zAk (zak_winkler)      Join Date: Jan 2005       01-23-2005, 10:26 AM Reply
i have a 03 moomba outback wiht about 750 lbs in the back i was woundering if that will be enough to surf wihtout the rope? i was also woundering wat kind of board i need. im a first time wakesurfer. i would like to have some fun with a good board. i looked at a broadcast . wat are peoples thoughts on boards.
Old    Steve Stafford (stevstaf)      Join Date: May 2001       01-24-2005, 5:47 PM Reply
I like my CWB Ride. Haven't tried the Broadcast.
Old    buttskimmer            01-25-2005, 5:47 AM Reply
Bigger boards are easier to ride and can be used with smaller wakes. You will need to weight the side of the boat you ride on. Get a extra sack and put it along side of the engine. Are you right foot forward or left????
Old    zAk (zak_winkler)      Join Date: Jan 2005       01-25-2005, 10:06 AM Reply
im right foot forward
Old    chudog2            01-25-2005, 3:50 PM Reply
The broadcast is a great board, esp. for guys as its big. You will need more than 750 lbs unless you have 6 guys in the boat to help weight down. I load my boat up w/ 2100 lbs and always want more.
Old    zAk (zak_winkler)      Join Date: Jan 2005       01-26-2005, 11:16 AM Reply
i changed my mind i might look at a landlock is that any good
Old    Johnny Wadd (surfnfury65)      Join Date: Aug 2004       01-26-2005, 1:13 PM Reply
I like traditional style surfing. I have the Shred Stixx Blow fish. It's 5'8"x22"x2". I am 6' almost 200#. It works killer. It also has a removable fin system so you can switch your fin set up. Great board. I haven't tried the smaller boards so actually I am no help.
Board More/Work Less!
Old    chudog2            01-26-2005, 1:47 PM Reply
The Landlock is also a great board. I have both the landlock and broadcast and have had a blast on both. Now that I have mastered the traditional style surfing though, I am looking for a snub nosed board to spin 360s and tricks on. I like the Inland Surfer Red Chubby but it's so expensive..anyone suggest something else (For a Girl, 5'4")?
Old    buttskimmer            01-27-2005, 7:46 AM Reply
Right foot foward rides on the drivers side - a plus for you since the drivers weight will help. I started with a landlock also and now have the cubby. Sandy - the cubby is no more - but they have replaced it a simular size board and shape. Yep they are expensive, you might want to look at a CWB tsuminai - (my spelling sucks and the name of this board might not be the best givin the currect disaster)
Its about 295 vs 395 for the inland or phase 5.
Old    jmo52            01-27-2005, 10:00 PM Reply
I have a Tsunami. I like it so far but I am a total begginer,
Old    zAk (zak_winkler)      Join Date: Jan 2005       01-28-2005, 6:50 AM Reply
the Tsunami is a decent board, im a total begginer to, do u need a huge wake for that board or is a smaller one alright?
Old    jmo52            01-29-2005, 4:17 PM Reply
I couldnt say really I filled 1 tank (800lbs) and had a nice wake. This weekend I bought a 440lb to go in the locker. I'll let ya know.
Old    buttskimmer            01-31-2005, 11:03 AM Reply
Zak - a beginner,small board & small wake is not the best combination. Are you also a beginner wakeboarder/skater???
Its practice and a patient crew when learning with a big board & large wake. You just need more of both.
Old    Trace (trace)      Join Date: Feb 2002       01-31-2005, 12:36 PM Reply
learn to ride backside too. due to prop rotation, the wake has more power on the port side on all boats except Nautiques, and you won't have to switch weight around so much. i also think it's easier to learn 180s & 360s from the backside.
Old    chudog2            01-31-2005, 12:47 PM Reply
So I ride regular foot. And trying to spin 360's I rotate around heelside first (rotate to the left)...I make it almost al the way around but the last little part I either sink my nose or it shoots out from me. Is it easier to spin right, spinning into the wake toeside?
Old    buttskimmer            02-02-2005, 9:14 AM Reply
Yes spin into the wake. If you can afford a balance board to practice at home it will help alot. Whats happeneing is that when the board shoots out - you have too much weight on the rear--- nose dive is too much on the front.
Old    zAk (zak_winkler)      Join Date: Jan 2005       02-02-2005, 9:56 AM Reply
scott ive been wakeboarding for a long time and wakeskating for like 3 years so a big board wiht moderate wake will be alright or will i need a huge wake
Old    buttskimmer            02-03-2005, 6:56 AM Reply
Zak - wake size does matter. The bigger and curling like a wave is best. It can be done with smaller wakes - just harder to keep it going. Surfing is balance front to back to stay going. You should be able to "feel" the sweet spot.
Old    David P (evil_e)      Join Date: May 2004       02-14-2005, 11:57 AM Reply
Personally, I found the Landlock to be a little big and clunky, maybe good for someone new to surfing, but I love my Broadcast...
