Do you put on your life jacket when you use the Dry suite.
I have a Boost dry suite. If you dont let all the air out you puff up like a marshmello and float quite nice. I guess if you were to hit the water hard enough you might be able to bust a seal and start taking in water and sink like a rock. My question is how many of you where a life jacket when you wear you dry suite?
because ive seen peoples zippers rip or a suit get punctured and rip a huge hole in it,guess what the drysuit will fill up with water quick and you can sink...
I never used to wear a vest under my dry suit because it was a lot constrictive. then I got a hefty fine. so now I have a non cga vest and were it unde the dry suit. when the water is really cold, it helps to keep me warm
