Old     (eubanks01)      Join Date: Jun 2001       07-01-2014, 12:33 PM Reply
Any thoughts on an amp to power 3 sets of Wet Sounds 6.5's and a JL 12w3?
Old     (DavidAnalog)      Join Date: Sep 2013       07-01-2014, 3:47 PM Reply
At the smaller side you could look at the JL Audio XD700/5 and at the higher side a JL Audio XD1000/5. Personally, in an open boat I like to see the subwoofer powered on the higher side.
Maximum Class D efficiency.
Super high Class D switching speeds, at least 20 times higher than the audio bandwidth.
Always meets or exceeds its 14.4 volt rating even at a lower 12.6 volt supply.
Produces 97% of its 1 kHz power across the entire audio bandwidth.
Lots of input configuration flexibility.
Port for bass level control.
All input and output terminals along one side with a closed chassis and covered controls.
Old     (WakeDirt)      Join Date: Jun 2011       07-01-2014, 4:22 PM Reply
Don't mean to swoop on the thread, but David:
I am looking to take my current arc 600.2 that is running my two JL 10w3s sealed, and putting it to my Rev 8s. I currently have 4 rev 8s running on another 600.2, would like to have the two arcs for the tower...what JL XD is a good pair or similar to the 600.2? Currently subs sound really good and would like to keep the same power if not a tiny bit more... have used JLXDs in the past but am less familiar with them.
Old     (eubanks01)      Join Date: Jun 2001       07-01-2014, 4:23 PM Reply
Thanks David. What are your thoughts of running the same set up with an old PP 1000.4? Not ideal but not looking to drop another 6-800 if I don't have to.
Old     (DavidAnalog)      Join Date: Sep 2013       07-01-2014, 5:42 PM Reply
You can't run three 4-ohm coaxials in parallel but there is a configuration where two channels can drive six speakers with a fairly equitable distribution of power and run at a safe load. So in a 3-channel mode you can drive the sub and six coaxials. Depending on your speaker layout, you may lose an important ability to balance for coaxial positional dis/advantages by not having those extra two channels.
That is an all Class AB amplifier and it is a real current hog.
The original PPI was golden. But after being purchased by DEI they began to package the identical amplifiers in a variety of chassis by different brands. So I'm not sure which amplifier that is. But it will work.
Old     (DavidAnalog)      Join Date: Sep 2013       07-01-2014, 5:46 PM Reply
JL Audio has a Class D XD1000/1 that would be perfection for two 10W3s. Hopefully both are 4-ohm subs. If not then there are other ways to go.
Old     (eubanks01)      Join Date: Jun 2001       07-01-2014, 7:09 PM Reply
Thanks David! I should be finishing my system tomorrow.
Old     (WakeDirt)      Join Date: Jun 2011       07-01-2014, 11:39 PM Reply
Awesome thanks, and the difference in a JX 1000 D and the XD?
Old     (DavidAnalog)      Join Date: Sep 2013       07-02-2014, 5:52 AM Reply
The JX is a great value amplifier with lots of power (1000 watts) at a low cost. The 12.5 volt power numbers are especially impressive. Sophistication wise, it's more on par with competitors offerings.
The XD is a completely different animal with higher switching speeds, wider bandwidth, completely different input section, different features, all connections at one end, covered controls, plus all the added technology that distances JL Audio from its competitors.
Each one has a place.
