Old                10-05-2004, 4:32 AM Reply
Just start to do my progressive edge till I reached the wake, and got popped off to the air, the thing is, I never landed properly, I keep landed on my face. My friends on the boat said that My feet keep moving around when I'm in the air, as the result, either my front feet stuck or i landed sideways. How to make them stay in the position where they are before the pop? thanks
Old                10-09-2004, 3:09 PM Reply
place the handle lower on your body, near the front hip/leg side as always, and relax. pop, then enjoy the ride...your problem may be that you get pulled over when you pop because you're not strong enough to cope iwth the line tension. just keep it lower, and don't get pulled over at the torso.
Old                10-19-2004, 12:02 AM Reply
Hey, thanks for the reply man, I'll try that soon. thanks again
Old    Davo (davo00)      Join Date: Nov 2004       11-05-2004, 12:24 PM Reply
Number 1 rule.... Look OUT not DOWN.
If you look down when you land, you will fall down!
