Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through August 27, 2003 > Archive through September 24, 2004
Old    absolutofft            09-23-2004, 9:21 PM Reply
I have already pressure washed and then scrubbed the sides but there is still a light green water line visible. Would an acid cleaner be too much?
Old    Laci (tcluv85)      Join Date: Jan 2004       09-23-2004, 10:11 PM Reply
I used Starbrites Green Hull Cleaner and it came off with some scrubbing. If all else fails there is that rubbing compound by 3M.
Old    882001 (882001)      Join Date: Nov 2003       09-24-2004, 5:25 AM Reply
starbright "hull cleaner" is awesome. from greenish brown to bright white. spray it on hose it off.
Old    eric fox (fox)      Join Date: Jul 2002       09-24-2004, 6:23 AM Reply
Sno-Bol toilet bowl cleaner. Cheap, and easy. Don't forget to put a nice coat of wax on afterwards.
Old    Jason Pribyl (skibum69)      Join Date: Aug 2004       09-24-2004, 7:35 AM Reply
i second the star bright cleaner. it works great just don't get any in your eyes
Old    KG - (wakescene)      Join Date: Feb 2001       09-24-2004, 10:16 AM Reply
Castrol Super Clean & a good boat brush will get just about anything off!
Old    Karl De Looff (boarditup)      Join Date: Jan 2004       09-24-2004, 10:36 AM Reply
muratic acid - rinse off well. Wear protection. Be sure to rinse off the trailer. It will corrode any unprotected metal if allowed to sit on it.
Old    Lucky Charms (lchamaschuk)      Join Date: Feb 2002       09-24-2004, 1:09 PM Reply
Davis FSR (Fibreglass Stain Remover). Removes algae lines every time!
Old    Rod (rvh3)      Join Date: Jul 2003       09-24-2004, 2:10 PM Reply
Karl is right. Wear glasses and gloves. All of the products mentioned above will burn you skin and eyes. I use Star Bright and it works wonders.
