Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through November 30, 2004
Old    cinekw            09-23-2004, 8:25 AM Reply
Just purchased 1990 SN and I want to use it for wakeboarding but the wake is very small, can someone tell me how to weight it down to get good size wake, also please post some pictures of the Ski Nautique wake.
Old    Peter_C (peter_c)      Join Date: Sep 2001       09-23-2004, 9:05 AM Reply
Fat seat with another sack on top of it in the back, then find a way to get a full size sack in the bow. With at least 4 people in the boat, it should now be throwing a nice wake.
Old    yearling            09-23-2004, 12:43 PM Reply
This is a stillshot from a video camera so its really small and crappy. It kind of gives you an idea. This is when it was really lightly weighted, with about 500 in back and 250 on each side with 200 in the nose. We can get it over our knees with more weight. And its very solid.
Old    yearling            09-23-2004, 12:46 PM Reply
O yeah ethan is riding at about 65 feet at 19 to 20 mph. Hes about 5'6".
Old    Jeigh Krupp (balr54)      Join Date: May 2004       09-23-2004, 2:11 PM Reply
my buddy has basically the same boat but a few years newer. We threw a 600 pound fat sac in the back and had about 5 people in it. The wake was sick. It was well past my knees and I am 6'6, and it was really solid too.
Old    John Anderson (fly135)      Join Date: Jun 2004       09-23-2004, 2:37 PM Reply
This is a 92 Ski Nautique with about 650lbs of weight (in back) and two people. The rope length is 65' and the speed is 22mpg. It definitely takes a lot of wake to get a decent sized wake. I don't really consider the wake in this pic to be that great. Barely enough to be enjoyable.
Old    cinekw            09-24-2004, 6:46 AM Reply
It looks good, what kind of prop do you use on the boat ?
Old    John Anderson (fly135)      Join Date: Jun 2004       09-24-2004, 10:49 AM Reply
The stock 3 blade.
Old    King of PoP (troyl)      Join Date: Feb 2002       09-25-2004, 8:44 AM Reply
You can get into SAN territory with that boat but it will take 2200+lbs and 24mph. Also a prop change will be needed (call acme)for both power and to clean up the wake. There is a lot of room behind the gas tank for lead!
The rear seat can be removed and replaced with carpet covered hard tank, or a fat seat.
I found that a 2:1 ratio of rear weight to bow weight works well on Ski Nautiques. (not counting engine side sacks)
Old    cinekw            09-28-2004, 9:24 AM Reply
I am getting the ACME #612 3 blade prop, and I have 650 lbs fat sack that will go at the back and few people in the front.
Old    murrayair            09-29-2004, 9:13 PM Reply
I have an '88 Ski Nauti and put a 540lb fat seat on each side of the engine and a 600 lb sack in back, plus people, and i can get the wake pretty darn big. I had to get an Acme 542 prop to handle all the weight. Once you go Acme you will NEVER go back.
Old    cinekw            09-30-2004, 5:02 AM Reply
mark d (murrayair)
Show some pictures of your wake & setup if you can, I like the pic in your profile, is that you ?.
Thanks
Old    Richard (nauty)      Join Date: Feb 2004       09-30-2004, 8:25 AM Reply
Here's me behind a buddy's '96 Ski Nautique. It's weighted with around 2000 lbs ballast plus 3 people in the boat.
Sorry, I forgot the pic.
(Message edited by nauty on September 30, 2004)
Old    Richard (nauty)      Join Date: Feb 2004       09-30-2004, 8:27 AM Reply
Damn it, I get get the pic up.
Sorry!
Old    cinekw            09-30-2004, 9:34 AM Reply
Check out some pictures of my son and me behing 1980 SN with 2 people and 300 lbs.
http://www.wakeskate.com/Members/Member_PhotoAlbum_View.asp?PhotoAlbumID=368
Old    ricktrav            09-30-2004, 12:17 PM Reply
check out my profile it's only got 600lbs + 4 people in the boat
Old    John Anderson (fly135)      Join Date: Jun 2004       09-30-2004, 1:20 PM Reply
Marcin, pre-90 Nautiques have a different hull and cannot be compared equally to your boat.
Old    eric fox (fox)      Join Date: Jul 2002       09-30-2004, 6:30 PM Reply
JOhn is correct, those pre-90's boats are narrower. My friend has a 90 ski supreme and with the same number of people in the boat it sinks lower than my 92. We put a fat sofa in our boat and the wake started to get a bit intimidating. We're used to a few hundred pounds and some people though.
Old    murrayair            09-30-2004, 8:07 PM Reply
Marcin-I wish that were me! That, however, is Shaun Murray. I will try to have some pics up soon. I am not sure I have any pics of it with all 3 sacks in, but I will try to find some.
(Message edited by murrayair on September 30, 2004)
Old    cinekw            10-19-2004, 6:54 AM Reply
Please post more pictures !!!
Thanks
