Old    alan plotz (alanp)      Join Date: Apr 2001       09-22-2004, 10:00 PM Reply
well i think i may try a whirly. i can do them on the tramp no problem and i understand the rotation. my indy tantrums are getting better so im confident that i get enough vertical movement. i have questions about the rope placement. for indy tantrums i keep the rope much lower than i do regular tantrums(near my hip) do i keep the rope in a similar fashion or a little higher. also at what point do i start the head rotation. pull the rope in front of my face then rotation the head or rotate the head while pulling the rope up to my face. seems like i need to bring the rope handle to face then rotate the head. anything else?
Old                09-27-2004, 8:52 PM Reply
start looking as soon as you jump, after you jump look to the side and throw your arm across your chest and your body should rotate a little faster then the board which should come around at the very end of the trick.
