Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through September 23, 2004
Old    Kal Cotter (kalcotter)      Join Date: Aug 2004       08-31-2004, 7:49 PM Reply
hey all, my buddies and I have be boarding for 3 or 4 years now behind my dad's rinker. After finally getting sick of that, I just got a 1990 Malibu Skier in pretty good shape. The engines only 3 year old and it runs like a champ. This may be obvious but it has a lot better wake than the boat we were used to, but I would love to get a killer wake, so we can finally start to excel at boarding. I've heard of fat sacks and bladder bags and stuff, but I'm looking for a way to make the wake huge if I want it and small when I don't, because I also love to water ski. I'm not sure if such a thing exists, but any suggestions or comments would be great, I just want to have a wake so big I'm scared to hit it!
p.s. here's my new boat http://www.flashingback.com/malibu
thanks,
kal
Old    byerly137pro            08-31-2004, 7:52 PM Reply
The only thing I can think of is adding a ballast system if that is possible, which involves pumps and like 500lb tanks under the flooring. Maybe I dont know, I bet it would be expensive though.
Old    Thane Dogg (thane_dogg)      Join Date: Jun 2002       08-31-2004, 7:57 PM Reply
fill the sacks when you want to board, then drain 'em when you want to ski.
nice boat.
Old    Kal Cotter (kalcotter)      Join Date: Aug 2004       08-31-2004, 8:02 PM Reply
So, people drain them and fill them pretty often. Is that a pain in the butt, or pretty easy? I'm thinking of getting like a 1000 lb big grey bag from gotriver.com . I'm not really sure if I just lay it in the back seat of my boat, or where I would put such a monstrosity. Is a ballast system the same as a fat sac?
Old    walt            08-31-2004, 8:07 PM Reply
Do what Thane said... It only takes a few minutes to fill or drain the fat sacks. If it's a direct drive run two 600 pound fat sacks. one on each side of the engine and You will have a sick wake.
Here is a pic of My wake with two fat sacks.
Old    Kal Cotter (kalcotter)      Join Date: Aug 2004       08-31-2004, 8:12 PM Reply
call me dumb but I don't know what direct drive means.... and should I just lay the fat sacs on the floor of the boat beside the engine?
your wake is pretty sweet!
Old    walt            08-31-2004, 8:18 PM Reply
If Your engine is in the middle of the boat it's a direct drive. And Yes the sacks just lay on the floor. My friend has the same boat as You and runs the same sack set up and the wake is great !
Old    cheeseinaz            08-31-2004, 8:22 PM Reply
I assume it's a closed bow? In that case, 2 fat sacs filled up all the way on boths sides of the engine should do the trick. Check out www.gethighsports.net too for Fat Sacs-they have pretty good deals. You might want to add some lead or sand bags in the bow to distribute the weight more evenly. If you have too much in the back, the wake will be really "peakey" and by balancing the weight more front to back you will get a fatter wake. Slightly rampier. Good luck.
Old    walt            08-31-2004, 8:23 PM Reply
Here is another pic.
Old    Kal Cotter (kalcotter)      Join Date: Aug 2004       08-31-2004, 8:24 PM Reply
awesome, thanks for the tips, one last question, I don't suppose you know where I should start looking for 600 lb sacks?
Old    cheeseinaz            08-31-2004, 8:26 PM Reply
Read my previous message....
Old    walt            08-31-2004, 8:26 PM Reply
http://www.wakeside.com/page/W/CTGY/wakeboard_boat_ballast_bags
Old    walt            08-31-2004, 8:28 PM Reply
I like the Flyhigh sacks http://www.boardersparadise.com/merchant2/merchant.mvc?Screen=CTGY&Store_Code=WBS&Category_C ode=D1d
Old    Kal Cotter (kalcotter)      Join Date: Aug 2004       08-31-2004, 8:29 PM Reply
awesome thanks guys! soon I'll probably be attaching pics of me crash landing from 10 feet up!
later,
kal
Old    Jeff Bridges (jbjboc)      Join Date: Aug 2004       08-31-2004, 8:38 PM Reply
One other suggestion bro..... Have a pump for each sack- it makes things much quicker. Make sure they are 1000 GPM at least..... oh ya, and a splitter to plug in both pumps at once.....
ride on.....
Old    gobiggrom54            08-31-2004, 11:40 PM Reply
just find a lot of heavy stuff and put it all in the boat!
Old    Jeigh Krupp (balr54)      Join Date: May 2004       09-01-2004, 7:57 AM Reply
for awhile we were using 50lb cement blocks to weight the boat down. My roomates dad didn't like that too much and threw them in the lake, so we got a 600lb fat sac. Made a major difference. (we still sneak a block or 2 in sometimes for just that little extra weight though.
Old    C.I.E. J-Rod (jarrod)      Join Date: May 2003       09-01-2004, 8:24 AM Reply
install a wedge. 1000 pounds in 10 seconds.
sweet wake Walt!
Old    crowe            09-01-2004, 9:12 AM Reply
Form the pics of your boat, get a four blade prop. Not too much help with the wake, but will help the boat get moving with all that ballast.
Old    Kal Cotter (kalcotter)      Join Date: Aug 2004       09-01-2004, 9:39 AM Reply
I read that a wedge can be pretty hard on the engine,, any truth to that? Also, where do i find a wedge, or info on them...?
thanks
Old    C.I.E. J-Rod (jarrod)      Join Date: May 2003       09-01-2004, 11:09 AM Reply
Malibu dealer. I've seen lots of Wedges installed on older Malibus. But, I would call Malibu to see if they advise against putting a Wedge on the back of your specific model. They add a lot of stress to the hull of the boat. Malibu might recommend that you don't install a Wedge.
It's no harder on the engine than putting a thousand pounds in the back of your boat IMO.
Old    WakeXtreme (p_b_parks)      Join Date: Dec 2003       09-01-2004, 7:01 PM Reply
what if you put all the weight in the bottom in the middle of the boat? would it make it rampy? or peaky? what would the effct be?
Old    Leo Lasecki (malibuboarder75)      Join Date: Jan 2004       09-01-2004, 7:45 PM Reply
in the middle of the boat? it should be balanced so it would make the wake bigger then it is. If you put the weight in the back, then it will be steep, more up front it will be more mellow.
