Check out Shaft, Parks does an ollie backflip to blind. It's not an air roll either, he lands a trick way out in the flats, and with no line tension. He tosses a straight backflip and brings it to blind. About that tantrum, I learned to do them on a boat with a tower, but after I got them down real solid I could do them easy enough without a tower. Some tips for doing it though would be to focus on going higher than far. Most tantrums you see are taken way out in the flats, but it doesn't need to be. Take a pretty fast cut at the wake, then start to change edges at the spray. DON'T start to roll it over until you are in the air. Without a tower, I usually will pull in my legs pretty tight, just to make up for the height. Let me know how it goes.
