Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through September 23, 2004
Old    sbvfive            08-22-2004, 8:24 AM Reply
Just wondering how it was if you went...what was open, what wasn't etc???????
Old    Dave Burns (dbjts)      Join Date: Nov 2003       08-22-2004, 1:23 PM Reply
It closed for a minimum of two weeks as of the 16th
(Message edited by dbjts on August 22, 2004)
Old    John Anderson (fly135)      Join Date: Jun 2004       08-22-2004, 1:55 PM Reply
I was their Friday after work, Saturday, and today (Sunday).
- The big cable is closed so they were running the small cable at 30kph rather than the usual 32kph.
- The Fun Box is out of the lake right now.
- The Camo ramp is a little further out so you need to hit it harder and faster to come off the top.
- The dock between the two cables is a little messed up but still usable.
- They put a plastic barrel right after the starting dock so you can practice ollieing.
That's about it. The building didn't seem to suffer any damage. But the large cable will probably be out for a couple weeks. Not sure how bad it is. It doesn't look messed up but it's supposibly out of alignment.
Old    sbvfive            08-22-2004, 2:12 PM Reply
John, I knew you'd have the info...thanks alot! One more question....was the picnic table and the flatbar both in and useable?? What about the kickers?? Thanks again!!
Old    John Anderson (fly135)      Join Date: Jun 2004       08-23-2004, 6:36 AM Reply
Scott, the Flatbar, Picnic Table, and Kickers are fine. A couple people mentioned that the Picnic Table was a little closer in to the cable, but it wasn't that noticable. The Cheese Wedge was real low with the front lip sticking up a bit, but a couple of us pulled the front down tight Saturday morning so it's got a steep kick again.
Also the big White Kicker is a angled out a bit more with a little more incline, but it's not that big a change. The White Kicker could use more pop, but that's how it's been since they put it out.
