Old    swass            06-07-2002, 8:51 AM Reply
I thought I remember seeing a diagram of the right/wrong way to drive the double up. Any idea where it is?
Old    Abe Sosa (crowmobe)      Join Date: Aug 2001       06-07-2002, 12:49 PM Reply
may have been in one of last years issues of wakeboarding mag not sure which one sorry..
Old    swass            06-07-2002, 5:39 PM Reply
I meant on here somewhere. What's the turning radius? Tight turn? Big, wide loop?
I suppose I could dust off Detention, but...
Old    swass            06-07-2002, 5:45 PM Reply
Abe, thanks for the response, BTW.
Old    ridehyco            06-08-2002, 1:46 AM Reply
there is no right way...but there is a wrong way...
Never cross the double up rollers at more than 90 degrees. Shaun Murray says, "Just don't do it, just don't do it."
90 degree crossin will make steeper peaks thus throwing you higher. Plus I think they are harder to hit.
60 degrees is a good place to start. Still nice and big, but easier to hit and to get used to. They'll still get you up there, but you dont have to make a helluva cut to get over both wakes.
I like the 60 degree ones myself, 2nd or 3rd roller depending on how brave i feel. :-)
I think turning radious all depends on your boat. Sometimes making a tight turn makes the prop cavitate, thus losing speed. It's preferred to make a larger loop in order to ensure you cross the double up rollers at the right speed and right angle. However, space is sometimes limited.
You should also accelerate a bit into the turn b/c you will lose speed in the turn. And its easier to slow down to the correct speed than it is to speed up to it.
that's no diagram, but i hope it helps.
H
Old    andy zarlengo (colorider)      Join Date: Jun 2001       06-10-2002, 1:54 PM Reply
Swass, Last wed Eric drove a double up in Todds boat and it looked fairly easy. As for the boarder, timing is everything. Take off with us wed or thurs after work and he will show you how. Double ups are more important then a paycheck. Right?
