Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through August 01, 2004
Old    Patt Smulsky (p_e_ski)      Join Date: Jul 2004       07-27-2004, 12:44 PM Reply
Enjoying our first year as wakeboard boat owners. Have done all my own maint on my old Bayliner which was an outdrive. Now I need to know about v-drives. What is used to seal the opening where the prop shaft goes throught he hull from the prop to the gear box? What type of maint. needs to be done to keep it in good shape. Thanks......
Old    zboomer            07-27-2004, 1:01 PM Reply
It's just called a "shaft log." It has a seal around it composed of a sorta rope like material which is packed under a nut. As you tighten the nut, it compresses the packing material, sealing it off. The only maintenance required is to check the seal periodically, to see if it's leaking at the proper rate.
When sitting still, it usually won't leak at all. When moving, it should drip one drop every 15-30 seconds or so. In fact, it must leak a little. The water lubricates the shaft.
You adjust the tightness of the nut against the packing material to control the drip rate.
There are also dripless seals that some people install or order as options, but the vast majority of inboard type boats have the standard shaft log, which needs the periodic adjustment. it's very easy, and shouldn't take over a few minutes.
My owner's manual says to check it every 50 hours.
