Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through July 28, 2004
Old    hyp3rl1t3            07-26-2004, 10:24 PM Reply
Where can you get lead for more weight. I've been thinking about it but im not sure where to find it. Thanks
Old    Leo Lasecki (malibuboarder75)      Join Date: Jan 2004       07-26-2004, 10:29 PM Reply
hardware store?
Old    Robert Clarizio (rob_c)      Join Date: Feb 2003       07-26-2004, 10:33 PM Reply
go to your local tire store and ask them if you can have some of the old lead they use to balance rims
Old    Blabelmooch (blabel)      Join Date: Jul 2001       07-26-2004, 10:41 PM Reply
Wheel weights and sand in small shoebox size tupperware containers. Wrap in duct tape and that should give you around 40-45 pounds.
Takes a little bit of work but it's cheap.
Old    hyp3rl1t3            07-26-2004, 10:48 PM Reply
k thanks
Old    toolfan (toolfan)      Join Date: Jul 2003       07-27-2004, 7:07 AM Reply
go to a Tractor Supply and ask someone there if they know where you can get used tractor weights. they are 100 lbs slabs with handles. i have bought them for less than $5 a piece used. John Deer weights will cost more. Ask for Case/International or Massey Furgusson. New they sell for $100-200 a peice. Sometimes tractor junkyards will give them to you.
Old    mango (mango)      Join Date: Mar 2004       07-27-2004, 7:25 AM Reply
LeadHeadz
65 lbs. per brick
$1.00-$1.25/lb
Each LeadHeadz Ballast Brick is made with a purified, high grade lead that allows for the optimum weight in the smallest amount of cubic inches. The base design of each brick is 17 " long and 3-1/2" wide. On the each side of the Headz there are 3/4" Earz that allow for extremely easy handling in & out of the boat.
http://www.wakeworld.com/MB/Discus/messages/65921/66088.html?1052395056}
