Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through August 01, 2004
Old    HYPO (hypo303)      Join Date: Jun 2004       07-23-2004, 7:06 PM Reply
is there any websites with step by step instructions..
i ran over a little mud and sand last week just want to make sure its all out
do i just run a hose to it for 15mins or is there
something use i need to do
any info will help
Old    Wilson Lee (leewilson)      Join Date: Sep 2002       07-23-2004, 9:41 PM Reply
You need to buy Fake a Lake, it's basically a plunger with a hose adapter. Attach it in the water intake underneath the boat and start the water, then start the engine. This should flush out any mud. Good luck.
Old    Mikeski (mikeski)      Join Date: Aug 2003       07-23-2004, 10:13 PM Reply
You probably won't be able to flush anything out that didn't already pass. I wouldn't worry about it.
Old    jdr            07-25-2004, 6:07 AM Reply
get one of these:
http://www.westmarine.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10001&langId=-1&catalogId=10001&productId=91920
It's easier to use than a fake-a-lake.
Old    newtique            07-25-2004, 7:54 AM Reply
Where did you locate the Flush-Pro.....before the screen filter or after?
Old    jdr            07-25-2004, 7:26 PM Reply
Mine is before the screen filter, it's inline not far from the intake in the bottom of the boat. Make sure you have the "flow" arrow pointed the right way.
Old    Mikeski (mikeski)      Join Date: Aug 2003       07-25-2004, 11:17 PM Reply
Come on guys, anything that didn't shake loose at speed bouncing down the lake sure isn't gonna come out using a fake-a-lake or otherwise on a trailer after it has sat for a week. Forget about it.
Now if you really think there is something in the block you will need to pull the motor and have the water passages cleaned out by an engine rebuilder. I seriously doubt that it's necessary.
