Old    tjensen            07-28-2004, 7:05 PM Reply
Has any one run hose for a do-it yourself ballast system on a Malibu 99 Sunsetter LXI (or comparable). Iím curious about any gotchas you may have encountered or ingenious ideas of where you ran yours for your system before I tackle mine.
Thanks
ďStanding on the shoulders of giantsĒ
Old    Mikeski (mikeski)      Join Date: Aug 2003       07-28-2004, 11:07 PM Reply
See Tanks&More on E-Bay. They have all the hose and fittings you need at great prices. The white spiral hose works great for ballast systems. I even replaced my hard PVC with this stuff. They have it in almost any size you need.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=56984&item=3815327 045
The reversible Simer pumps from BE Atlas for $65 each work pretty well if you are not in too big of hurry.
My guess would be 500-600 up front and the same in back.
Old    tjensen            07-29-2004, 6:23 AM Reply
Thanks Mike, now I have all of the material and am ready to drill the holes for the hose. Hoping someone with a similar boat has already done it so they can give me advise on where to drill.
Old    John Klein (jklein)      Join Date: May 2001       07-29-2004, 10:41 AM Reply
I mounted my pump to the ski pylon under the floor. It's mounted up off the floor to keep it dry. I drilled a 1 inch hole from the bilge area into the ski locker. You'll see that the battery cables go through that area too. From there, I 'T'ed off and drilled a hole behind the battery in the storage compartment behind the observer's seat to get a hose into the bow cusion area.
I also ran a hose aft along the steering cable and up behind the back seat where I bring it out the side of the back seat and fill a bag between the engine box and the back seat.
I used a Jabsco Ballast Puppy reversable pump and a thru hull fitting.
Old    John Klein (jklein)      Join Date: May 2001       07-29-2004, 10:42 AM Reply
One more thing. If you do a thru hull, make sure you put a sea-cock valve on it before you make the transition from Bronze to plastic.
Old    tjensen            07-29-2004, 12:07 PM Reply
John,
Good stuff. I also am filling a sac between the engine compartment and seat. So Iíll follow the path you described. I have a question though about the route through the ski locker. I looked at where they ran the battery cables also, but since I am filling a 375lb sac in the ski locker I thought with the hoses running through there, there might be some restrictions when the sac fills up. My sac takes up the whole locker when Iíve filled it manually. Have you had any issues?
